I want to create a solid Buildings from surfaces, one surface is missing ,Can i create missing surface and complete the solid?
  • Oct 1, 2016 10:38 AM UTC
  • 103 views
Best answer by takashi
Hi @madhavan702, if you created every face of a solid as surface geometries, you can transform them into a solid with the SolidBuilder. Alternatively, a combination of the Aggregator and GeometryCoercer (Geometry Type: fme_brep_solid) can also be used.
  • Oct 1, 2016 10:52 AM UTC
  • Oct 1, 2016 11:11 AM UTC
But I have one side if the surface is missing, can I create the missed surface and proceed with solid creation????
  • Oct 1, 2016 12:17 PM UTC
if you have roof surfaces, try BRepSolidBoundaryCreator.Beta transformer from Hub.
