I want to be able to retrieve a PDF from an open access website on a weekly basis.
  • Dec 17, 2020 1:09 AM UTC
  • 44 views
 I have been able to do this using the HTTP caller. The issue I have is the the URL that I am calling changes slightly each week. The number in the URL increases by one each week. Is there a way I can automate the change in the URL so that it will retrive the up to date document from the link?
Thanks in advance for any assistance.
  • Dec 17, 2020 8:38 AM UTC
You can use the DateTimeStamper to first get todays date. Then use the DateTimeConverter with either of the following output formats to get the week number:
%U for Sunday-based week numbers
%W for Monday-based week numbers
Interestingly it seems that the FME week numbers are 0-based, so you may want to use e.g. an ExpressionEvaluator to add 1 to the result.
You can then integrate the resulting week number into the URL.
@mark2atsafe​ @lenaatsafe​ Does it make sense that the week numbers start with 0? And what should be the week number for 20210101? According to Google it's 53, but the DateTimeConverter returns 0.
