I tried to create a storyboard on fmedesktop as in the attached file, but I need something to be able to transfer the location information. What is this thing?
  • Aug 27, 2022 6:37 AM UTC
  • 32 views
mohamdwassouf
Welcome
I hope you can help me find a solution to this problem
I really need help to solve this problem
In the attached form, I have successfully exported the data from the Revit program to the ifc format
The data has a geographical reference specified by coordinates on a map in the Rift
I want to transfer this data to citygml format while keeping the site coordinates
muzhnasto
Forum|alt.badge.img+12
  • Nov 2, 2022 4:26 PM UTC
Hi @mohamdwassouf​  Your original geometry is at zero, do you know the coordinates where you need to move the model? Maybe it will help you https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/offsetter.htm
