I set a temporary file location, FME_TEMP, for temp files but this has led to the Data Inspector not showing any data from the Inspector.
  • September 2, 2016
  • 9 replies
  • 177 views
I have set a temporary file location, using the instructions found here : https://knowledge.safe.com/articles/176/fme-temp-environment-variable.html
However, when I run a workspace with data going into an Inspector, the FME Data Inspector window opens, but no data is loaded in/displayed.
I can see data has gone into the FME Temp space fine, and writing to file works fine, it's just the Data Inspector.
Does anyone know how I can rectify this?
Thanks!
erik_jan
Forum|alt.badge.img+26
  • September 2, 2016
This seems to be a case for support@safe.com
itay
Forum|alt.badge.img+19
  • September 2, 2016
Sometimes the data inspector gets stuck restarting it of the all machine can help
mark2atsafe
Forum|alt.badge.img+59
  • September 2, 2016
Yes, definitely if the Data Inspector and/or Workbench havn't been restarted since you changed the path.
mark2atsafe
  • September 2, 2016
Do you have the log window open in the Data Inspector? That might give us a clue about why it is having problems.
  • September 5, 2016
Hi Mark,
Yes I have restarted both (in fact I re-installed FME completely in case it had got stuck on something!).
All the log files say is: Log File: F:\\FME Temp\\FMEDataInspector\\logs\\fmedatainspector_2016-09-05T09-50-45.log
Is there anything else I can try?
Thanks
mark2atsafe
  • September 6, 2016
Hi Mark,
Thanks
What I'm looking for is that the Workbench log says "Storing feature(s) to FME feature store file" C:\\OneTempFolder\\inspector.ffs and the Data Inspector log says something like 'Couldn't find file D:\\AnotherTempFolder\\inspector.ffs' - because that will show whether the data is being written to the correct place (and the DI doesn't find it) or whether Workbench is writing it to the wrong location. And maybe the locations that are being used will reveal a clue as to why it's not working.
mark2atsafe
  • September 6, 2016
It shouldn't be an issue, but make sure the temp folder you are using has no spaces in its file/path names, and no special characters either. Like I said, it shouldn't be a problem, but it's one of those things to test for just to make sure.
  • September 7, 2016
Thanks Mark - I removed the space in the file name and this worked - I should have thought to check this. Thanks for all your help.
mark2atsafe
  • September 7, 2016
Yeah, not sure why I didn't think of it sooner. It's filed with the developers as PR#64578 and hopefully will be fixed before long.
