I have a table with two Columns A and B like that: A B 1 1 1 2 1 3 2 1 3 1 7 4 4 7 And my result should look like that: A B 1 1 1 2 1 3 4 7
  • May 18, 2022 8:49 AM UTC
  • 57 views
michellem
So I want to delete the duplicates, or find the distinct combinations across two columns.
I know I can do that with SQL on a database. But I just have a table here and want to do that directly in my FME script.
Does someone has an idea?
Best answer by ebygomm
You can use an AttributeCreator/AttributeManager with a conditional statement to create a new value that is always the lower value followed by the higher value. Then a duplicatefilter to get only the unique records
Forum|alt.badge.img+54
  • May 18, 2022 9:05 AM UTC
Do you have a table with two attributes? Or a single attribute with two values separated by a hyphen?
michellem
  • May 18, 2022 9:08 AM UTC
Oh sorry, I have a table with 2 columns. I just seperated the columns here with a hyphen.
I think this is missleading. I change it.
  • May 18, 2022 9:30 AM UTC
michellem
  • May 18, 2022 9:35 AM UTC
Thanks, that's it!
