I have a somewhat complicated question to resolve. I have this data set to translate (attached image). How can I merge the repeating values in the first attribute in this case?
  • Dec 25, 2020 5:10 PM UTC
  • 82 views
giuseppecfgeo
Forum|alt.badge.img+5
I would like to merge them keeping the first value of the other attributes but, the main problem is that the values that repeat "two by two" must be merged in pairs and sometimes the pair of values repeats, so the "group by" solution is not valid, because it would group all the identical pairs into a single value. Advice? I hope I was clear.Question_FME_community
Best answer by debbiatsafe
Hi @giuseppecfgeo​
If the input data is always paired and already ordered, then I would recommend using the custom transformer GroupCounter (group size: 2) and then a Group By on the output _group attribute.
debbiatsafe
Forum|alt.badge.img+24
  • Dec 25, 2020 8:34 PM UTC
Hi @giuseppecfgeo​
giuseppecfgeo
  • Dec 25, 2020 9:06 PM UTC
Oh my god, thank you so much for this answer, that's probably just what I need! Thanks so much!!!😲 💎
