I have a record formatted as follows
  • Aug 5, 2022 3:52 PM UTC
  • 6 replies
  • 73 views
nID='1' nOperTime='2022-07-31 23:51:56' szUserName='default' EventType='Save Config' Remarks='Saved -P2P- config.IP:Local LoginUsername:default Group Name:user'
I want to split this into nID, nOperTime, szUserName and EventType
I've tried using the KeyValueAttributeCreator transformer to do this with:-
Key,Value Delimiter: =
Key,Value Separator: <a single space>
After this runs I see thousands of columns created with name 1,2,3,4... which appear to be the value of nID rather than the key. I wonder if the issue is the quotes and if so is there a solution that will see quoted fields as a single value?
Best answer by markatsafe
@davebarter​ Thanks @ebygomm​ for the clever regex. I've attached an example workspace based on that approach. FME 2021.2
@davebarter​ There's a StringSearcher regex solution here but I can't see it:
(\\w+='[\\d\\-\\s:]+' )
gets the first name/value (nID='1' ), but I can't see how to make the sub-expression to repeat for subsequent name value pairs. If someone can figure out how todo that then the StringSearcher with Subexpression List Name will give you what you need I think
Forum|alt.badge.img+54
  • Aug 5, 2022 7:15 PM UTC
If you use a string replacer with some regex to replace all the spaces outside of quotes with pipe | or similar you can use that as the Delimiter int he KeyValueAttributeCreator transformer
I think this regex should work
\s(?=(?:[^\']*'[^\']*\')*[^\']*$)
  • Aug 5, 2022 7:27 PM UTC
     (\w+='[\d\-\s:]+' )
If you wanted to use this approach to get a list you could use this regex
(\w+\=\'[^\']+\'?)
Which would give you each element as a list value
  • Aug 5, 2022 7:42 PM UTC
If you don't need the process to be dynamic and always know the value of your keys you could also do something like thisimage
  • Aug 5, 2022 8:22 PM UTC
  • Aug 8, 2022 9:55 AM UTC
Thanks All!
@Mark Stoakes​ @ebygomm​ that works a treat
