I have a polyline dataset which contains asset types as attributes. Based on these different asset types I would like to subtract a value from the Z-coordinates so that the lines will be displayed at the correct depth.
I was thinking I can use an attribute filter to filter the different asset types and subsequently use a 3Dforcer to lay the different polylines on their correct depth. As an example I used the following parameters in the 3Dforcer for 1 attribute of the field asset type:
Elevation: @ZValue()-1
Preserve Z-values: No
The result was as follows:
1 polyline features has 3 vertices:
Before translation:
1st
vertex Z: 0,6
2nd
vertex Z: 0,8
3th vertex Z: 1,0
After translation:
1st
vertex Z: -0,2
2nd
vertex Z: -0,2
3th vertex Z: -0,2
What I would like to have:
1st
vertex Z: -0,4
2nd
vertex Z: -0,2
3th vertex Z: 0
This translation provides a constant Z
value based on some average of mutliple vertices. I want it to take into
account each individual Z and then substract the ammount specified.
Best answer by dustin
I think the transformer you need is the Offsetter. This will allow you to offset the z based on the different asset types.
dustin
Forum|alt.badge.img+36
  • October 25, 2022
  • October 25, 2022
Thank you that was exactly what I was looking for
