I have a lookup table and a grodatabase. I have select only feature classes from geodatabase which is included in the lookup table
  • Jan 18, 2024 6:21 AM UTC
  • 59 views
harish
Forum|alt.badge.img+11
I have a lookup table in which some feature class name is mentioned. I have to select in the feature reader only those features from geodatabase which in there in the lookup table. How to do that. One more problem here all my feature classes is in the feature dataset in input geodatabase. In output I want this outside feature dataset
srinivasgg
Forum|alt.badge.img+7
  • Jan 18, 2024 8:05 AM UTC
Use featurereader - use gdb and select your geodatabase
harish
  • Jan 18, 2024 9:51 AM UTC
I want to make the workbench dynamic that is why i am taking feature class name from the Lookup table. So the option suggested you for manually selecting it will not work.
srinivasgg
  • Jan 18, 2024 12:53 PM UTC
I think you can control it by using " Feature Types to Read" and " WHERE clause" constraints in FeatureReader parameters.
