I have a dynamic workflow that takes files and loads them into postGIS using FeatureWriter. I am having issues with datasets that contain date fields with some null values resulting in features getting skipped.
  • Nov 23, 2022 5:03 PM UTC
  • 119 views
tomcolley
Forum|alt.badge.img+4
The writer seems to be trying to write '00000000' for these features rather than leaving it as null
Is there a way to stop this behaviour? In a standard workbench I could set a default value but it feels like I shouldn't need to do that as postgres can handle null values in date fields and I don't know how I could change the values as it's a dynamic schema.
Errors in log:
Value of attribute 'createdate' could not be converted to type 'date'. Feature will be logged and skipped
Attribute(string: UTF-8)      : `CREATEDATE' has value `00000000'
Schema definition for field:
attribute{8}.fme_data_type fme_date
attribute{8}.name CREATEDATE
attribute{8}.native_data_type date
The next line is missing for features that do not have a value:
CREATEDATE 20031118
Best answer by ebygomm
Thanks for you're comment, you are indeed correct the values are 00000000 before they go into the writer, the issue seems to be with the Shapefile reader as the values are null in the dataset when viewed in QGIS but are being padded out when read in FME:
NEXTTEST (string: UTF-8) 00000000
Shapefiles don't officially support null values which is why you don't see them as nulls. See
https://community.safe.com/s/question/0D54Q00008OcM97SAF/interpretation-empty-attribute-shape
Forum|alt.badge.img+54
  • Nov 23, 2022 6:32 PM UTC
Are you sure that before the writer the value of CREATEDATE is null and not 00000000 ?
I have no issue writing nulls to a postgres date field
tomcolley
  • Dec 21, 2022 10:59 AM UTC
  • Dec 21, 2022 11:40 AM UTC
tomcolley
  • Dec 21, 2022 2:22 PM UTC
Thanks very much, that makes sense now.​
