I have a custom coordinate system, I was confused how to translate it for MyCoordSysDefs.fme
  • May 16, 2014
  • 84 views
Hi, I have a custom coordinate system that I was confused how to translate it to the MyCoordSysDefs.fme for use in Safe Desktop. Here's how it is represented in the prj file.
PROJCS["Lumos_Projection_Foot",
GEOGCS["GCS_North_American_1983",
DATUM["D_North_American_1983",
SPHEROID["Geodetic_Reference_System_of_1980",6378137,298.2572221008916]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-80],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",4921259.843],
PARAMETER["false_northing",0],
UNIT["Foot_US",0.30480060960121924]]
I read over the help for FME DEsktop, but the I did not know how to translate it because it had two units and so many Parameters.
I appricate any help. Thanks
Best answer by takashi
additionally, I would recommend you to have a look at properties of some similar coordinate systems.
Open Coordinate System Gallery (Menu: Tools > Browse Coordinate Systems), select a coordinate system (e.g. NY83-EF), and click Properties button to show Coordinate System Properties. You can see how "OGC WKT Description" should be mapped into "Coordinate System Properties" for FME.
Takashi
  • May 19, 2014
  • May 19, 2014
Takashi
  • May 19, 2014
maybe a bit outside what you were asking, but there are a lot of interesting resources and coordinate system template to look at here (http://spatialreference.org/).
David
