I get this error in the log file when I do a line on area overlay. Can someone help me understand what is happening and how to fix it?
  • Feb 14, 2018 2:47 PM UTC
  • 81 views
Feature is not a 'line (spaghetti)'. Migration to 'point' attempted for feature destined for table 'ACE.T_OH_LINE'
Error while generating line shape for Table 'ACE.T_OH_LINE'. Scale Factor may be too small.:SDE_ERROR_CODE(-148) The number of points is less than required for feature
lau
Forum|alt.badge.img+3
  • Feb 14, 2018 4:08 PM UTC
Your line is really small (1.22e-5 m). Is it normal? I have the impression that FME try to convert it to a point because of its very small length
erik_jan
Forum|alt.badge.img+26
  • Feb 14, 2018 4:09 PM UTC
Looks like, because the coordinates of the line are so close to each other, a tolerance causes the line to be snapping into a point feature. And point features are not allowed in the LineonAreaOverlayer.
Number of Coordinates: 2 -- Coordinate Dimension: 2
(1469669.0493342665,1389805.8701952382)(1469669.0493462486,1389805.8701975448)
  • Feb 15, 2018 2:10 PM UTC
Is there a parameter that can be set to not split a line that will result in an additional line being this short?
lau
  • Feb 15, 2018 3:40 PM UTC
There is several possibilities.
In your case you can add a tester that allows lines above a determined length to pass:
