I am working with Spatial Fuzzy matcher but at many places it is showing the fuzzy ratio 1 but there are no such data there?
  • Jun 8, 2023 9:48 AM UTC
  • 68 views
I am working with two datasets and I am trying to use Spatial fuzzy matcher to find if there is a similar name nearby within the mentioned distance in this transformer but wherever the fuzzy ratio is 1 it is not there.
EG : here I am tryimg to find if there is 'Heavy inlet' in another dataset or similar string, it has mentioned its fuzzy ratio as 1 but there is nothing similar to this near or in the entire dataset.image.pngimage:
daveatsafe
Forum|alt.badge.img+24
  • Jun 9, 2023 9:40 PM UTC
Hi @mitinaupwanshi​,
I would recommend leaving a comment for the author of the transformer at https://hub.safe.com/publishers/spatial-kat/transformers/spatialfuzzymatcher#comments. This will make them aware of the problem you are experiencing.
