I am trying to use the BIM360 Docs Connector transformer and it is throwing an error related to a Python library. The error is "No module named 'fmepy_autodesk_bim360docs'".
  • Feb 17, 2022 11:41 PM UTC
  • 0 replies
  • 34 views
gerryjames
I am trying to use the BIM360 Docs Connector transformer and it is throwing an error related to a Python library. The error is "No module named 'fmepy_autodesk_bim360docs'". I had originally setup a custom Python interpreter environment using Anaconda so I originally thought it might be that. However, I changed the environment back in FME to Python 3.X (I tried 3.6, 3.7, and 3.8) but no luck. I did check the FME python install location for this file with no luck. Has anyone seen this before?
