It is a large data set. If there are no values, I want to send the data to a writer, if there are any values, I want to go to the terminator. My issue is that the data set is large and using a tester or attributeValidator isn't work because values are getting to my writer before validation is complete.
I am trying to test an entire field to see if there are any populated values.
Best answer by ciarab
Try the feature holder as it will hold all the records until the last one arrives. So your null records should hit terminator before the last correct record arrives at the feature holder.
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
