I am attempting to load a GML file into PostGIS via FME and get the following error: Bulk copy failed on table 'public.physical_oceanographic_map' using delimiter ':'. Error was 'ERROR: extra data after last expected column
  • Aug 15, 2022 10:23 PM UTC
  • 63 views
Sample data from the gml file:
` <gml:featureMember>
  <nzodn:physical_oceanographic_map fid="physical_oceanographic_map.fid-4332c03c_1829f0e6782_-2349">
   <nzodn:stationName>U3693</nzodn:stationName>
   <nzodn:url>https://nzodn.nz/data/physical_oceanographic/sage/SAGE_CTD_data_U3693.txt</nzodn:url>
   <nzodn:time_coverage_start>2004-04-07T10:50:00</nzodn:time_coverage_start>
   <nzodn:time_coverage_end>2004-04-07T10:50:00</nzodn:time_coverage_end>
   <nzodn:hasTemperature>true</nzodn:hasTemperature>
   <nzodn:hasSalinity>true</nzodn:hasSalinity>
   <nzodn:hasChlorophyllFluorescence>false</nzodn:hasChlorophyllFluorescence>
   <nzodn:hasTransmissionOfLight>false</nzodn:hasTransmissionOfLight>
   <nzodn:hasFluorescence>false</nzodn:hasFluorescence>
   <nzodn:hasPressure>true</nzodn:hasPressure>
   <nzodn:hasDissolvedOxygen>true</nzodn:hasDissolvedOxygen>
   <nzodn:hasComment>false</nzodn:hasComment>
   <nzodn:geom>
    <gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
     <gml:coordinates xmlns:gml="http://www.opengis.net/gml" decimal="." cs="," ts=" ">172.693333,-46.236333</gml:coordinates>
    </gml:Point>
   </nzodn:geom>
  </nzodn:physical_oceanographic_map>
 </gml:featureMember>
 <gml:featureMember>
  <nzodn:physical_oceanographic_map fid="physical_oceanographic_map.fid-4332c03c_1829f0e6782_-2348">
   <nzodn:stationName>U3691</nzodn:stationName>
   <nzodn:url>https://nzodn.nz/data/physical_oceanographic/sage/SAGE_CTD_data_U3691.txt</nzodn:url>
   <nzodn:time_coverage_start>2004-04-07T08:58:00</nzodn:time_coverage_start>
   <nzodn:time_coverage_end>2004-04-07T08:58:00</nzodn:time_coverage_end>
   <nzodn:geom>
     <gml:coordinates xmlns:gml="http://www.opengis.net/gml" decimal="." cs="," ts=" ">172.695667,-46.235</gml:coordinates>
    </gml:Point>
   </nzodn:geom>
JennaKAtSafe
Forum|alt.badge.img+9
Hi @byroncinnz​ it sounds like your GML may have some syntax errors. How are you reading in your GML? Would you be able to share a sample workspace?
