HTTP Caller Sending Too Many Requests (Slack Webhook)
  • Oct 14, 2021 9:42 AM UTC
  • 46 views
I am running a workspace that detects changes in data between an API and Web App and applies only updates to the Web App using a change detector transformer. I am sending a notification to a Slack Webhook but instead of a single HTTP request being made, it makes 1 request for each data record updated.
What I Want:
"Successfully updated 70 records".
What is Happening:
"Successfully updated 1 records".
"Successfully updated 2 records".
And so on till 70...
Is there a transformer that will allow me to sum the number of updated records and only send a single HTTP request to the Slack Webhook?
Workbench Screenshot:
Thanks!
Best answer by oscard
You could use the transformer FeatureCounter followed by a Sampler of just one feature.
Or you could use the StatisticCalculator. There you have a function for total count of features.
oscard
Forum|alt.badge.img+23
  • Oct 14, 2021 9:46 AM UTC
Thanks very much. Both methods were acceptable. I used the StatisticsCalculator as it's simply a transformer less.
