HTTP Caller Patch Salesforce
  • May 8, 2024 3:26 PM UTC
  • 113 views
cnorth
HI,
I’m looking into using HTTP caller to update records in my Salesforce Org I am struggling to get anything workisng, I have tried to setup a connected app to setup a FME web Connection but keep getting an error. The aim is that another service calls the FME job and it runs and updates a record in Salesforce, we have the record ID for each run so we know what record and field to update but I’m also not sure using the HTTP Caller how to have it refresh the token also?
I have also tried following this guide
https://support.safe.com/hc/en-us/articles/25407494166029-Connecting-to-Salesforce-in-FME
but everytime I try to test it come up with a Network Error: invalid_request
Any direction would be appreciated.
Thanks
LizAtSafe
Forum|alt.badge.img+26
  • May 10, 2024 10:52 PM UTC
Hi @cnorth,
The first thing to try would be to GET any information from Salesforce to make sure that everything is set up correctly. I test all of my calls in https://workbench.developerforce.com/login.php?startUrl=%2Fselect.php before moving to FME to make sure the call is set up correctly and I have the right permissions enabled.
Another option would be to use the SalesforceConnector first with the web connection to make sure that is working before moving to the HTTPCaller.
Hope that helps get you started
