How to write line with measure to Postgis?
  • Jun 17, 2020 2:21 PM UTC
  • 152 views
I'm creating line with measure on vertex and write it to postgis. When I read the same line from postgis, there is no measure.
Is-it possible to write and read measure from Postgis?
Thanks
Best answer by markatsafe
@miladahmad Yes. FME can create PostGIS tables with measures. MeasureGenerator will create measures on a features. The first feature written to a table dictates the structure of the geometry. So make sure the first the features written to the table have measures.
The attached workspace illustrates this. The Sampler has the first feature skip the MeasureGenrator so the table is created with no measures. Remove the Sampler and the table will be created with measures.
Example workspace (FME 2020): PostGIS measures.fmwt
Alternatively, create the tables using pgAdmin or SQL in SQLCreator.
  • Jun 17, 2020 6:02 PM UTC
  • Jun 17, 2020 7:29 PM UTC
Thanks for your answer. I do the same but when I read from postgis, the line do not have measure. What do you mean by creating table with SQL? Should I write 2 tables or what? Simply, I have a line, I generate measure and write it to Postgis. Should I do something else?
Thanks
krien
Forum|alt.badge.img+10
  • Jun 17, 2020 9:00 PM UTC
Hi miladahmad,
Are you writing to the same PostGis table as you are reading from in the workspace?
If so, I suggest you read the line from the existing PostGis table, add the measure to it and write it to a new table so that table has the spatial DataType with measure in it.
Put the original lines in that new table and use this table as input for adding the measures.
Kind regards,
Krien Guijt
  • Jun 17, 2020 9:29 PM UTC
Hi miladahmad,
Kind regards,
Krien Guijt
thanks a lot. It's working now. I find that it is strange that I should write the table 2 times.
