How to validate CityGML XML file in FME ?
  • May 31, 2022 1:58 AM UTC
  • 136 views
maybe if you have the correct schema for xml validation, can you share it with me ?. Because I don't understand how to validate the xml citygml schema in fme
Best Regards
itsmatt
Forum|alt.badge.img+48
  • Jun 1, 2022 11:22 AM UTC
There are two options - you can set the CityGML reader to perform validation against the schema when reading
OR
you can use the XML validation transformer with the following Settings (assuming CityGML 2.0)
