How to use BoundsExtractor ?
I'm sorry, i'm FME's beginner.
I need some help. I'd like to use BoundsExtractor in order to know xmin, ymin, xmax and ymax but it doesn't work.
I'm working with Polygon and i just want to know the extent or xmin, xmax, ymin and ymax.
Sorry for my english.
Regards,
Ter
  • March 19, 2015
the BoundsExtractor doesn't touch the geometry, it only adds attributes containing the min/max coordinates.
If you need the bounding box geometry, consider using the BoundingBoxReplacer or BoundingBoxAccumulator.
David
  • March 19, 2015
Hi David,
That's the problem. I can't see the news attributes containing min/max coordinates.
I don't know what's the problem. I have a new shapefile without attributes.
  • March 19, 2015
Thank you !!! :) It's working.
gio
Forum|alt.badge.img+15
  • March 19, 2015
when you enter a writer you must, if needed laways add attributes yourself.
Unless you are doing it dynamically.
