How to supply the resolution dynamically with the RasterPropertyExtractor?
  • Dec 10, 2020 11:31 AM UTC
  • 71 views
Hello im relatively new to FME and I want to determine the resolution of raster images with the transformer "RasterPropertyExtractor", how can i set this transformer to supply the resolution dynamically? Because I want to use the workspace for different images with different resoulutions.
Thank you and Best wishes Barrylim
Best answer by jdh
The RasterPropertyExtractor will ouput amongs other things the _spacing_x and _spacing_y attributes. You can use those values later in your workspace, including setting up testFilters to have different resolutions have different processing steps.
jdh
Forum|alt.badge.img+41
  • Dec 10, 2020 3:51 PM UTC
  • Dec 11, 2020 11:55 AM UTC
Thx for your reply it worked :)
