How to select the latest feature class from ESRI file geodatabase
  • Aug 29, 2023 1:59 PM UTC
  • 114 views
wil
Forum|alt.badge.img+5
I have a file geodatabase where backups are stored with a date in the name that gives the backupdate, BU_20230724, BU_20230731 etc. How can I select that only the latest will be read for further analysis? Normally, a feature class is selected under Constraints > Tables and you can select the one you need but, the latest Backup will not stay the same during the year. In a automated proces I would like to select the one with the latest date without changing it manually.
Best answer by david_r
You can use the Schema reader to extract all the feature class names, use a Sorter and a Sampler (first 1) to get the latest and then send the name to a FeatureReader.
  • Aug 29, 2023 2:11 PM UTC
wil
  • Aug 29, 2023 3:48 PM UTC
Many thanks, that's it.
