How to remove small gaps in separate sets of polygons, while keep overlapping areas in tact
  • March 31, 2016
  • 66 views
fmelizard
Forum|alt.badge.img+22
We have sets of concentrical circular patterned polygons, and there are small gaps between the curved boundary. SliverRemover removed the gaps, but also removed part of the overlapping polygons. Snapper takes a long time, because the curved borders of the polygons are thousands of small line segments. Any suggestions on how to effectively resolve this issue?
Hi @FMEZipster, I think the Snapper is a suitable solution, although it could take a long time. If you can make groups for each set of concentric circles, the performance might be improved by setting a group ID attribute to the "Group By" parameter. Do the features have an attribute that can be used as a group identifier?
