How to remove short lines only from a set of disconnected lines?
  • Nov 4, 2020 12:26 PM UTC
  • 6 replies
  • 167 views
CaptureSo I want to remove all the shorter lines from the above while keeping the rest.
nielsgerrits
Forum|alt.badge.img+67
LengthCalculator and a Tester?
  • Nov 4, 2020 1:02 PM UTC
Can you give an example? I tried it but I'm missing some settings I think in some of the transformers?
  • Nov 4, 2020 1:11 PM UTC
Ill send my fme proj
When using a tester you will want to view your data in the Data Inspector first to see what the output from the LengthCalculator created. Then you will pass that value to the tester as a _length >= (value)
The column will have values like this
len
  • Nov 4, 2020 1:32 PM UTC
len
Can you send an example proj file at all? As I'm not sure how to do it? Thanks in advance.
  • Nov 4, 2020 1:50 PM UTC
Heres an image..... I don't think my CurveFitter is actually producing a list of lines?
Capture
