How to plot a line from a text file when all the Y coordinates are in a row followed by all the X coordinates in a row?
  • Jun 23, 2020 8:30 PM UTC
  • 5 replies
  • 108 views
paul_m
Forum|alt.badge.img+26
I have a series of text files that I am trying to create lines from. Each row in the text file has the number of vertices followed by the Y coordinates for all the vertices and then the x coordinates for all the vertices (see example below)
3,41.1380602942863,41.1378946727126,41.1378187626848,-111.856708809171,-111.857316620769,-111.857869454434
Does anyone know how I could break these up into an X,Y format to use something like the LineBuilder to create lines?
Thanks!
Best answer by ebygomm
One possible way to get pairs of coordinates
Split into a list by the comma, count the length of the list, explode the list into parts, discard the first item in the list (the number of coordinates), create an x attribute if the element index is less than or equal to half the element count -1, create a y attribute if the element index is more than half of the element count -1, use a modulo counter to assign a coordinate index, aggregate together to get coordinate pairs
You could then create points and use a point connector make lines
Forum|alt.badge.img+54
  • Jun 23, 2020 9:33 PM UTC
Split, explode, filter, count, rename XY, and merge.
From there, use a VertexCreator and a LineBuilder to generate the lines.
  • Jun 23, 2020 9:48 PM UTC
In reality though, I'd probably use a pythoncaller to create the geometries, something like this
import fme
import fmeobjects
def processFeature(feature):
    #get value, split on comma to get list and remove first value, convert to floats
    mylist = [float(i) for i in feature.getAttribute('value').split(',')]
    #get num coordinates
    numcoords = int(mylist[0])
    #get first n items in list (excluding first)
    y = mylist[1:numcoords+1:]
    #get last n items in list
    x = mylist[numcoords+1::]
    #create list of tuples
    coords = list(zip(x,y))
    #set geometry
    feature.setGeometry(fmeobjects.FMELine(coords))
  • Jun 24, 2020 7:12 AM UTC
x and y need to be the other way round of course, now I've noticed you say y coords first but same principle
paul_m
  • Jun 24, 2020 9:28 PM UTC
Thank you, your response helped a ton! I had multiple rows, so I made a few adjustments:
  1. Added a Counter before the List Exploder
  2. Used the Counter and the coordinate index (Modulo Counter) in the Aggregate group by parameter
  3. Added a Vertex Creator, Sorter (sort by _count and _element_index), and Line Builder (group by Counter)
