how to move the rectangle to right side ?
  • Apr 5, 2024 11:26 AM UTC
  • 104 views
soly
Forum|alt.badge.img+3
Hello
I would like   to move the rectangle in the direction of  right side ?
fme 2021
thanks in advance
Best answer by itsmatt
You can use the Orientor.
This will reverse the order of the vertices for the polygon. If the desired result is to move/shift a rectangle to the right (positive x direction) then an Offsetter should be used
tomfriedl
Forum|alt.badge.img+14
  • Apr 5, 2024 11:51 AM UTC
itsmatt
Forum|alt.badge.img+48
  • Apr 5, 2024 12:06 PM UTC
