How to match boundaries?
Hi, I am new to FME and am excited to get started. I have a task that should me simple, however I am not sure how to go about it. I have two Arc feature classes I need their boundaries to match with no gaps or overlaps. I used Arc to erase one with the other. Now I need to align them so each has a vertex where the other has a vertex. I can do this manually in Arc but I would prefer to automate it. Can I do this in FME and can you please tell me how to use which transformer? Thanks!
erik_jan
Forum|alt.badge.img+26
  • May 25, 2016
I would have a look at the Snapper transformer.
I will thanks
gio
Forum|alt.badge.img+15
  • May 26, 2016
you could first filter out arc-boundaries with a spatialfilter.
Then use a arcproperty extractor to extract arc parameters.
Remove arcs, recreate arc with 2dArcReplacer using parametervalues you extracted.
You control this using the list from the Spatialfilter (containing wich id's share a certain arc-boundary)
