How to get fractional seconds from gdb date-field
  • Jul 26, 2016 10:30 AM UTC
  • 70 views
i have features in a ESRI FileGeodatabase with date-attributes and i need the fractional second.
I played around with the dateformatter-transformer, but i don't see a date format symbol for fractional seconds.
Any ideas to persuade fme reading the fractional seconds?
Hi @thilo
you can probably handle your date values as a strings. Does FME read something like 201607261115263? If yes, you can use StringReplacer to replace first 12 characters with nothing
  • Text to Match: \\d{12}
  • Replacement Text:
  • Use Regular Expressions: Yes
or AttributeCreator to get the right three characters from the original values:
  • Attribute Value: @Right(@Value(_date),3)
  • Jul 27, 2016 6:25 AM UTC
Hi @LenaAtSafe,
replacing the first 12 characters gives only the seconds, but i need also the fractional part (something like this: 2015-03-23 10:23:45.213 => .213 , taken from DateFormatter Online-Help).
The Documentatiion of DateFormatter says, that the fractional seconds are not supported. I thought that that would be valid only if I use the DateFormatter and not in general.
A simple test-workspace (copy , duplicate reader on writer, gdb2gdb) shows, that the date-values are rounded to seconds, the fractional part are lost.
