How to find closet point at same small polygon
  • Jan 26, 2023 3:27 PM UTC
  • 87 views
gogopotter90
Forum|alt.badge.img+14
I have too many points A and too many points B and I have many small polygons .
every small polygons contain point A but some of them include point B .
i would like to to find each point B that close to point A but it should be at the same small polygon
if point A does not find point B ,at same small polygon so it will be better if i can mark it .that no point B close to point A .
FME 2021
Thanks in advance
Best answer by redgeographics
Thanks but why should I use group by in neighbour finder ,only to understand more .
The group by is to make sure that points from set A will only consider points from set B as potential neighbors if they have same polygon id value, i.e. if they are within the same polygon.
Forum|alt.badge.img+63
On a question like this it would be very helpful to see a small sample of the data.
Assuming the polygons have an id attribute (and if they don't you can use a Counter to create that)
First a PointOnAreaOverlayer for both points A and B to assign the id of the polygon(s) to the points, then a NeighborFinder with a group by on the polygon id.
gogopotter90
  • Jan 26, 2023 11:10 PM UTC
