how to extract the polygon that has the largest area at each value change of an attribute ?
  • Jan 19, 2018 9:51 AM UTC
  • 5 replies
  • 179 views
Example
Name Surface
2 15
2 25
4 10
4 20
4 15
5 15
5 10
Result
Name Surface
2 25
4 20
5 15
Thank you
oscard
Forum|alt.badge.img+23
  • Jan 19, 2018 9:58 AM UTC
Hi!
Have you tried the StatisticsCalculator transformer?
Group By: Name
Attributes to Analyze: Surface
Forum|alt.badge.img+54
  • Jan 19, 2018 11:39 AM UTC
You could also sort by surface in reverse order then use a duplicatefilter filtering on name to keep only the polygon with the largest surface for each name
  • Jan 19, 2018 2:57 PM UTC
Thank you egomm
how do i filter 250 names?
gio
Forum|alt.badge.img+15
  • Jan 19, 2018 3:33 PM UTC
@40_eme
Sort by Area descending and name.
Then use a Sampler, 1, first N features.
  • Jan 24, 2018 8:25 AM UTC
Thank you. The answer from Gio works perfectly.
