How to extract the extents of a point cloud?
  • Apr 6, 2023 10:18 AM UTC
  • 272 views
I need a polygon or closed polyline of the extents of this data; using max and min (x,y) gives a bounding box which means further down my pipeline, data is being written to areas that should take "No Data". How can I grab extents from the point cloud to use it as a breakline?
Pictured; point cloud, and point cloud overlaid raster output, showing data written outside the point cloud extents
Forum|alt.badge.img+54
  • Apr 6, 2023 1:55 PM UTC
I think when i've done this in the past I've coerced the pointcloud to a single multipoint with a PointCloudCoercer and then used a hull accumulator
