How to cut polyline into multiple segments based on nearby point data
  • Mar 26, 2020 6:28 PM UTC
  • 94 views
Lets say I have a polyline that covers a road, and on that road there are multiple stoppage points represented by another layer (point layer), how can I segment that 1 polyline to autocut to the closest point in its vicinity? (the points are not always overlayed exactly ontop of the polyline).
Here is an example
So for this 1 polyline I am trying to get 11 pollines where it would break at each dot.
Best answer by ebygomm
The point on line overlayer will chop your line with points. There is a tolerance setting which will handle points not sitting exactly on the line
Forum|alt.badge.img+54
  • Mar 26, 2020 6:33 PM UTC
Thanks I'll try that.
