How to create points where elevation changes by 0.5 feet along 3D stream feature class?
  • Oct 5, 2020 6:31 PM UTC
  • 33 views
I have a 3D stream feature class. Each vertex has an elevation representing water surface elevation for a 100 year flood. I want to create a new point feature class at the inflection points along the stream profile, where elevation changes by 1ft.
Here is my stream in profile view and some examples of where I want to create points: StreamInflectionPoints
My idea is to store the starting value then look at the next vertex, if less than 0.5, skip and move onto the next vertex. Continue this till I hit a vertex that is 0.5 or greater from the starting point. Then create a point at this vertex. Then, move to the next vertex and compare with the last created point.
I'm pretty new to FME, can this be done? Thanks!
itsmatt
Forum|alt.badge.img+48
  • Oct 5, 2020 7:23 PM UTC
Yes! In the AttributeCreator there is a way to look at adjacent features. ​https://www.safe.com/blog/2017/08/adjacentfeatureattributes-evangelist166/
This makes it pretty easy to compare ordered features.​
