How to concatenate consecutive LRS geometric segments in order to create a new LRS geometric segment?
  • Feb 13, 2021 5:19 AM UTC
  • 68 views
arthy
Forum|alt.badge.img+8
Hello,
I have consecutive Oracle LRS geometric segments in several locations that I would like to concatenate (see attached or the description below).
First LRS Geometric Segment : from distance a1 to distance b1
Second LRS geometric Segement: from distance a2 to distance b2 with a2=b1
Third LRS geometric segment: from distance a3 to distance b3 with a3 = b2
Nth LRS geometric segment from distance an to bn with an= bn-1
I'm able to write a query to merge all the N geometric segments and to compute the distance from (a1) and the distance to (bn).
How can I create the corresponding LRS geometry which will be the concatenation of all the touching geometry segments in the right order?
arthy
  • Feb 13, 2021 5:22 AM UTC
Any suggestion?
@Takashi Iijima​, @jdh​, @david_r​  and others?
jdh
Forum|alt.badge.img+41
  • Feb 15, 2021 2:42 PM UTC
I would probably just use a LineCombiner followed by a MeasureGenerator to get a clean set of measures.
If that is not desirable you would need to create a list of all the (new) measure values for each line and use a MeasureSetter in mode Whole Line.
