How to composite image color all subforder?
  • Sep 25, 2014 6:56 AM UTC
  • 49 views
hoa_le
Hi Everybody,
I have a folder including subfolders such as:
LC81230522013228LGN00
LC81240492013283LGN00
LC81250522013306LGN00
Each subfolder, I have multiple bands landsat which has structer ending : _B1.TIF,  B2.TIF, ..., B11.TIF.
I want to composite color for each subforder automatic. The output file will export to original subfolder.
Could you tell me how can I do? Thanks
  • Sep 25, 2014 8:09 AM UTC
Hi Hoa,
If you need to transform several single-band rasters into one multiple-band raster, the RasterBandCombiner might help you.
And I would recommend you to learn about Dataset Fanout to distribute the resulting rasters to the original folders.
Takashi
hoa_le
  • Sep 25, 2014 2:31 PM UTC
Hi Takashi,
Thank you for your support. I know RasterBandCombiner function but I have not know Dataset Fanout to distribute the resulting. Could you send me link how to do that? Thanks
  • Sep 25, 2014 2:42 PM UTC
I think this is a good start point.
Separating Output Data With Fanout (http://docs.safe.com/fme/html/FME_Workbench/Default.htm#About_Fanout.htm)
