How to avoid deleting small polygons when using Generalizer ?
  • Apr 16, 2014 2:07 PM UTC
  • 5 replies
  • 77 views
I have a dataset containing large and small polygons. When I generalized the layer, preserving the shared boudnaries, small pieces get deleted.
Is there w way to avoid deleting small polygons ?
Best answer by gio
Apart form filtering small sized polygons.
The various generalising schemes have options to control the amount of generalizing.
If u have it generalise to much, small objects will enter the range of generalisation and be removed altogether.
So its about tolerances, smoothingfactors, angels etc.. Experiment with these will help.
Gio
  • Apr 16, 2014 2:48 PM UTC
that would probably depend on the algorithm selected in the Generalizer.
Which algorithms have you tried?
David
  • Apr 16, 2014 2:49 PM UTC
I use Douglas
Thanks
  • Apr 16, 2014 3:00 PM UTC
The best result is when I use Douglas. Other algorithm still removed objects.
However, I have a work around using "Changedetector" then "Clipper" that will reinsert the removed objects.
Generalizer should maybe have an option "prevent shape removal" , as seen on mapshaper (http://www.mapshaper.org)
gio
Forum|alt.badge.img+15
  • Apr 16, 2014 3:53 PM UTC
Gio
gio
  • Apr 16, 2014 4:06 PM UTC
well..not with angels of course..angles are more usefull here...:)
