How to access a zipfile from a URL which contains a GML file?
  • Oct 5, 2020 9:00 AM UTC
  • 5 replies
  • 118 views
lambertus
Forum|alt.badge.img+25
I want to download a zipfile using an URL and continue with the GML file which is within this zipfile.
The following URL contains the zipfile:
http://geodata.nationaalgeoregister.nl/top100nl/extract/kaartbladen/TOP100NL_33W.zip?formaat=gml
I tried to use the HTTP caller first with these settings:
HTTP method: GET
Save Response Body to: Attribute
..then I used the FeatureReader to open the output of the HTTP caller.
However, I got stuck. The HTTP caller did not generate any output.
Could you advise me in this?
  • Oct 5, 2020 9:24 AM UTC
You can simply point the reader directly to the URL that returns the zipped GML, for example:
2020-10-05 11_24_13-Add Reader
Result:
2020-10-05 11_24_13-Add Reader 2
Forum|alt.badge.img+54
  • Oct 5, 2020 9:26 AM UTC
You need to set Save Response Body to: File
You should then get a feature exiting the HttpCaller with an attribute of _response_file_path which you can use as the dataset in the FeatureReader
lambertus
  • Oct 5, 2020 9:56 AM UTC
Result:
Thanks for your reply!
I added a GML reader like you did but got some errors like shown in this image:
Just ignore the other transformers, that was another trial :)
Errors fme GML Reader
  • Oct 5, 2020 10:06 AM UTC
I can confirm that I get the same error with FME 2019. But with FME 2020.1 it works just fine and I was able to read the entire dataset. You may want to consider upgrading, you can keep both versions as long as you install them to separate directories.
https://www.safe.com/support/downloads/
lambertus
Thanks a lot! Works perfect. Small remark, I added a Creator before the HTTP caller.
