how keep the nighbour of clipper?
  • Dec 21, 2019 7:08 AM UTC
  • 5 replies
  • 52 views
charry
Forum|alt.badge.img+5
I want use cyan Circle clipper Pipeline diagram?but I want to keep red section,how Ishoud do?
  • Dec 21, 2019 7:32 AM UTC
Hi @charry, if you intend to filter out only features completely contained by the cyan ellipse, consider using the SpatialFilter.
Send the cyan ellipse to the Filter port, send the red features to the Candidate port, and set "Filter Contains Candidate" to the Spatial Predicates to Test parameter in the Spatial Filter.
The SpatialFilter with the settings above would output required features from the Failed port, if I understood your requirement correctly.
charry
  • Dec 21, 2019 9:25 AM UTC
no,I want use clipper transformer to clip terrain or Pipeline, But I want to keep the line Adjacent section .
  • Dec 21, 2019 10:37 AM UTC
I'm not clear why you attempt to clip. Does this fit your requirement?
Select the features which intersect the cyan circle with a SpatialFilter, then from the Failed features select ones which intersect the Passed features from the first SpatialFilter, using another SpatialFilter.
Spatial Predicates to Test: Filter Intersects Candidate
charry
  • Dec 23, 2019 3:04 PM UTC
How to understand this?
becchr
Forum|alt.badge.img+35
  • Dec 23, 2019 3:11 PM UTC
hi, that's a junction, here it's just added for layout-reasons i guess
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/Using-Junctions.htm
