How does the AttributeValidator transformer process unique feature? Specifically, cloned attribute values.
  • May 6, 2020 7:38 PM UTC
  • 5 replies
  • 94 views
alexlynch3450
Forum|alt.badge.img+16
Is there a way to reject or fail all features containing same value? Right now I would ideally like a way to route all features containing same value to failed port. Currently, for example, if I clone 1 record 3-time, two features fail and one feature pass. How do I route all features that have non-unique values to failed port?
Best answer by alexlynch3450
@jlbaker2779 @ebygomm : I was able to route features using uuidgenerator-->matcher-->attributecreator-->aggregator-->listRenamer/Remover-->attributeValidator-->listElementCounter-->Tester
csv22xlsxw.fmwt
Forum|alt.badge.img+54
  • May 6, 2020 8:27 PM UTC
I'm not sure it's possible with the attribute validator, but you can use a matcher to find features that all share the same values.
I think I see what you're doing.
To generate some arbitrary data I used a creator with 5 duplicate values and a 2nd with 1 unique value.
Using the statistics calculator and group by function you can get a count of records. Anything with 2+ records is a duplicate and would be sent though the <Unfiltered> (failed port) of the attribute filter. The 1 value on the attribute filter would be all unique values.
alexlynch3450
  • May 7, 2020 6:19 PM UTC
csv22xlsxw.fmwt
alexlynch3450
  • May 7, 2020 6:21 PM UTC
Think I figured it out.
Feel free to advise on workflow tweaks if bug or discrepancies are found.
alexlynch3450
