How do I use TextStroker Version 2
  • April 23, 2014
  • 5 replies
  • 88 views
fmelizard
Forum|alt.badge.img+22
With TextStroker [version 1], there was a parameter "Text String Attribute". This contained the string attribute which was to be stroked. Worked fine.
However, in TextStroker V2 this parameter is gone. I now don't appear to have any way to tell the TextStroker what it is meant to be working on.
I tried putting a GeometryCoercer (to FME_Text) in front of it, but of course that doesn't let you pick an attribute either.
So how do you use TextStroker V2? What am I missing?
Cheers,
Jonathan
  • April 23, 2014
Hi Jonathan,
A text feature has a hidden attribute which stores the text string, called "fme_text_string". Is it the thing you need?
Takashi
fmelizard
  • April 23, 2014
Hi Takashi,
  Hmmm. That seems to be a user-interface regression - they've hidden something that was exposed in an earlier version.
But then - how do I turn something intoa  fme_text_string? Or do I just use the AttributeCreator/Setter?
Thanks,
Jonahtan
  • April 23, 2014
you can just use an AttributeCreator (or equivalent) to set a suitable value for "fme_text_string" manually.
David
fmelizard
  • April 23, 2014
Yep that works. But I'll feedback to Safe that it seems like a regression anyway.
Thanks for the assist!
  • April 23, 2014
That is good to hear.
I do agree that "fme_text_string" should be mentioned in the TextStroker documentation, at the very least.
David
