How do I output <null> in attribute table after calculation
  • May 13, 2022 7:40 AM UTC
  • 67 views
Hello Sir / Madam,
So I would like to subtract both "Top Height" and "Rooflevel" attributes.
I use attribute manager to calculate the value
@round(@abs(@Value(TopHeight)-@Value(ROOFLEVEL)),1)
The result is shown as below.
However, I want my result to be <null> if either TopHeight or Rooflevel is <null>. May I ask how to do it?
Thank you.
Zachary
Best answer by ctredinnick
You can use a Conditional Value. It's in the dropdown when you set an attribute value in the AttributeManager, underneath 'Open Arithmetic Editor'
ctredinnick
Forum|alt.badge.img+22
  • May 13, 2022 7:53 AM UTC
Got it! thank you so much for your prompt response! :)
