How do I manage the attribute order in shapefile writer
  • Dec 27, 2022 3:07 PM UTC
  • 105 views
I have a project in which I generate four shapefiles. In 1 of the shapefiles I add new attributes via transformers and fill them with a specific value. But even though I have neatly arranged the order of the attributes in my writer, this is not followed in the output in the shapefile. The added attributes are in other places than indicated in the writer itself. How can I ensure that the output is neatly arranged as I want it?
Best answer by JennaKAtSafe
Hi @ellendp​! A few ideas come to mind here:
If you are looking to order your attributes you could add an AttributeManager before your writer and use the arrow buttons on the bottom left corner to order your attributes. If you're looking to arrange your features in a certain order the Sorter transformers might help. Let me know how this goes for you!
JennaKAtSafe
Forum|alt.badge.img+9
  • Dec 27, 2022 11:18 PM UTC
  • Dec 28, 2022 8:16 PM UTC
Hi JennaAtSafe,
Thank you. The AttributeManager does the trick. Never know you could order the attributes with this transformer. Thanks for letting me know!
