How do I add a folder with FME Packages SDK
  • Nov 21, 2024 12:52 PM UTC
  • 70 views
malthern
Participant
I have been using the FME Packager in Python to create my own transformers. I am trying to add an “images” folder to my package that my transformer will use however I get errors whenever I try to package my project.
This is my package.yml file, Ive been using the Hello World Package guide for references and trying to look up ways to do it
This is my file structure
This is the error I get
debbiatsafe
Forum|alt.badge.img+24
Hello ​@malthern
Apologies for a delayed response!
I did some testing and found that you cannot specify an image folder in package.yml as package validation will fail, as you have experienced.
However, you can place the image folder (or any other folder) inside either the help or transformers directory and the folder containing the images/files will be included in the output .fpkg.
I hope this information helps!
