How can I move a solution from my development environment to the test environment and ultimately production?
  • Oct 24, 2016 4:52 PM UTC
  • 224 views
fmelizard
Forum|alt.badge.img+22
We are risk averse here at Lizard Inc. and we utilize a a three stage dev/test/prod environment to ensure that no bad code or configurations get into our production system. Production must work!!
How can we move a working solution from an FME Server development installation to a testing/staging installation and ultimately to our production install?
Best answer by fmelizard
This is so easy in FME Server 2017.0 using new functionality called Projects.
Check out this video showing how to create a project for the purpose of moving it from one FME Server installation to another:
http://www.screencast.com/t/QwUMqtYe5PvM
Check out this video showing how to export the project from one FME Server and import it another FME Server:
http://www.screencast.com/t/QTOMx2WG0Na
fmelizard
  • Oct 24, 2016 6:22 PM UTC
fmelizard
  • Oct 24, 2016 6:30 PM UTC
If you are using FME Server 2016 or previous, then you don't have access to Projects.
Here is what you can do instead:
https://knowledge.safe.com/articles/19635/fme-server-workspace-life-cycle-for-the-enterprise.html
fmelizard
  • Jun 2, 2017 12:59 AM UTC
Also, if you need each environment to use it's own database, then you can define a database connection on each FME Server that shares the exact same name, but differs in the host and credential info. When a workspace is moved from one FME Server to the next, it will just connect to the database defined in the connection.
Relates to this somewhat:
https://knowledge.safe.com/questions/34975/moving-workspaces-between-fme-installs-tips-and-tr.html
fmelizard
  • Aug 18, 2017 3:38 AM UTC
Here is also a tutorial on the Projects feature available in 2017.0 and newer:
https://knowledge.safe.com/articles/44299/tutorial-automation-planning-and-deployment-with-f.html
