How can I extract the attributes from gdb file
  • Nov 29, 2022 8:44 AM UTC
  • 5 replies
  • 272 views
Hello Sir / Madam,
I have a gdb file that have several layers. I am just wondering how can I extract all attributes from the layers?
I tried "Schema" reader and list exploder to explode the data. However, I only able to get one table attributes. May I ask how can I extract all attributes from all layers? I have attached a sample data in here.
Hope someone can give me a hand. Thank you!
Thank you in advance.
Forum|alt.badge.img+63
The Schema reader should create one feature per table, can you check whether that's the case?
Hi, I am not sure what's wrong with my settings. I have attached the capture screen here. Could you please take a look at my setting, if possible.
The arrow pointed in ArcMap is the only table attributes that I can extract from. However, I would like to extract the other four attributes name as well (WallSurface_surface, Building_surface, etc).
Thank you very much.
It looks like the other tables are an unsupported geometry type and therefore FME skips them:
FileGDB Reader: Feature class 'Building_surface' has shape type 'esriGeometryMultiPatch' which is unknown to FME. Skipping feature class
Got it! thank you very much!
dustin
Forum|alt.badge.img+36
  • Dec 15, 2022 11:52 AM UTC
@zacharylee1204​ You can use a FeatureReader for reading the schema features, followed by a ListExploder to get those values as an attribute. Workspace is attached.image
