How can I ensure that my layers match the correct features?
  • Jan 26, 2021 4:26 PM UTC
  • 51 views
Hi, I want to check my dataset( with different layers), which contains polygon and line features for correctness. Which Method can I use to check if there are Layers filled with the wrong features? To check it manually is no option, because the dataset is to large.
hkingsbury
Forum|alt.badge.img+73
  • Jan 26, 2021 8:57 PM UTC
Geometry filter will allow you to filter out lines and polygons/areas
If you have a layer and want to compare a changed layer you can use the ChangeDetector.
Thank you!
