How can I deal with arcs from DWG file
  • Dec 23, 2020 6:47 AM UTC
  • 69 views
kolasunny
Participant
I have a DWG file that contains some arcs that are recognized as arcs and some as polylines with multiple segments. I would like turn all of them to arc with two nodes (start and end) with center point, radius and a rotation (cw or ccw). What would be the best steps that I would be able to take to achieve this?
davtorgh
Forum|alt.badge.img+12
  • Dec 23, 2020 7:51 AM UTC
Hi @kolasunny​ ,
maybe you could try the ArcEstimator.
Hope that helps!
@kolasunny​  ArcEstimator is probably your best starting point as suggested by @davtorgh​ If that doesn't give you the results you want try Generalizer using the Douglas with arc Fitting algorithm
