How can I convert shapefile into asc or text file?
  • Mar 9, 2018 4:50 PM UTC
  • 6 replies
  • 167 views
I´d like to know how can I convert the shapefile into (formated) asc file.
  • Mar 9, 2018 5:32 PM UTC
I need to extract the shapefile geometry (x, y).
jdh
Forum|alt.badge.img+41
  • Mar 9, 2018 5:56 PM UTC
You can use a CoordinateExtractor followed by a listExploder to get one set of x,y coordinates per fetaure (per line when written out as a text file), but without knowing the exact format of the the acc file, it's a little hard to give concrete suggestions.
  • Mar 10, 2018 5:21 AM UTC
What is the geometry type of your Shapefile dataset? Point?
  • Mar 10, 2018 3:19 PM UTC
My shapefile geometry is point.
I really don´t worry about the asc format. My main objective is extract the xy coordinate from shapefile geometry.
  • Mar 11, 2018 12:10 AM UTC
As @jdh suggested, you can use the CoordinateExtractor. If the geometry type is single point (not multipoint), you can use the transformer with these parameters.
  • Mode: Specify Coordinate
  • Coordinate Index: 0
gio
Forum|alt.badge.img+15
  • Mar 12, 2018 3:54 PM UTC
Depends on what you want to do with the stored geometry.
Depending on that and the geometry type of the shapefile you have multiple options.
Apart from creating a geometry string yourself (more complex) u can use a geometry extractor (to WKT for instance).
