How can I convert IFMETriangelFans to fme_polygons
  • Dec 14, 2017 9:36 AM UTC
  • 140 views
I have buildings with very complicated roof structures which I need to extrude to the terrain level to create new models.
During the process I need to use the GeometryCoercer to convert them to fmepolygons. The process was unsuccessful as many surfaces were missing.
This error message was indicated..
GeometryCoercer: Cannot coerce from IFMETriangleFan to fme_polygon
How can I overcome this ?
Takashi, can you help me?
  • Dec 14, 2017 10:21 AM UTC
Hi @annachong, as far as I know, there is no transformer to transform a TriangleFan to Polygons by a single step. Probably you need to use a series of some transformers.
I found two possible ways.
Triangulator -> GeometryCoercer->GeometryPartExtractor
GeometryExtractor -> GeometryReplacer -> AreaBuilder
And a Python script.
# PythonCaller Script Example
# Transform a TriangleFan or a TriangleStrip to Polygons.
import fmeobjects
class FeatureProcessor(object):
    def input(self, feature):
        geom = feature.getGeometry()
        if isinstance(geom, fmeobjects.FMETriangleFan) \
            or isinstance(geom, fmeobjects.FMETriangleStrip):
            for i in range(geom.numParts()):
                polygon = geom.getAsFaceAt(i).getAsArea()
                feature.setGeometry(polygon)
                self.pyoutput(feature)
        else:
Hope this helps.
  • Dec 14, 2017 1:25 PM UTC
Thank you, Takashi.
The second method works.
Now I have to solve a new problem at the end of my workspace
